Status
Not open for further replies.
1 - 15 of 15 Posts
I am looking for a power strip that will accept an AC trigger source. I want to plug my 3 amps into the power strip and have the power strip triggered when I turn on my reciever. Niles used to make the AC-6+ but they discontinued it. Any suggestions?
Look through the products at Niles, Sonance, Xantech, Panamax, and I'm sure others. The products certainly exist, it's just a matter of how much they cost and if you have to buy too many other features which you won't use. What you should also remember is that you can plug a 12V "wall-wart" into the back of your reciever which could then provide a 12V signal to a power control module of some sort.
I posted this in response to a similar request like three weeks ago.
Just make one. Use a 12 or 6 volt relay that has the power handling capabilities for the 120 volt feed. Depending on how fancy you want to get this can be very profressional.
I used an old extension cord and cut the hot wire to test it. Worked great so I gutted and old upc power strip. I connected the relay in line with the power switch and put a barrel connector on the side (used an exacto to get the hole right). I then made a double ended barrel connector to my receiver. Whenever the recevier is on the relay closes and the power strip is active. I can still use the power switch on it if i need to deactivate it for some reason. Going cheap you could probably do this for less than 20 dollars.
"Use a 12 or 6 volt relay that has the power handling capabilities for the 120 volt feed. "
Also, be sure the relay coils current requirement is below the current ability of your trigger. And if a person is using 'balanced' AC they *must* switch both neutral and hot wires.
Shawn
I've got a Monster PowerCenterâ„¢ HTS2000 that has a trigger input as well as a rocker switch. The box said something about it being an "installer's" version. I wasn't expecting that feature -- I can't find any mention of it on their web site -- but I was happy to get it. I ordered it over the web more than a year ago and I've forgotten which site I ordered it from. Let me know if you want me to check.
-Jonathan
I purchased two of the Niles iPower strips a year ago and love them. Very well made; not flashy, but they got the job done. A friend in San Francisco just went hunting for them and found out the same thing--Niles went out of the business. He tried calling around at different places to see if anybody had any left in stock and got nowhere. I believe that he decided that some of the Panamax products will fit his needs.
I had a similar issue with my AT1504 amp which I acquired a couple of weeks ago.
After some initial searching, I went to the local electronics store and purchased a 3 pole double throw 20A relay with a 120 V coil (for the trigger), a box to hold the relay, a 120V led (just to show that the power is on), an outlet etc .. and spent one evening putting it all together. Cost about $35 all inclusive (relay, led, cables, box, plug sockets, cable reliefs etc). Cheap, simple and works. It also switches hot, neutral and ground.
Radio Shack did not have a relay that could switch 20A .. but they do have one that switches 10A I believe. At worst, you could put them in series (incidently the 10A relay at Radio Shack was less than half the price of the 20A that I found).
Good point. I hadn't noticed.
You definitely want to make sure your amps don't exceed the capacity of the surge protector. I will be using two units for exactly that reason.
/jab
Discussion Starter · #13 ·
I picked up a Paramax 1500 from Onecall for a very good price. It fits the bill very nicely. I asked their customer service and it has no problem with a reciever and 3 outboard amps plus other equipment. Granted, it is supplied by a dedicated 15 amp circut. It has 4 switched, 4 always on and 2 delayed outlets. It also acts as a high quality surge protector ( even has inputs/outputs for 3 tv antenna inputs plus a phone line) and power conditioner. Very flexible unit.
The Max 1500's aility to handle three amps would depend on the current drawn by the amps. In my case, I'm reasonably sure I won't be able to drive all of my equipment (including 1600W of amplification) off my single 1500, which has a limit of 15A / 1800W. I'll be looking for a second 1500 or a pair of 4300's by the time I get everything installed.
I would encourage anyone considering loading up a surge suppressor to add up the power requirements of their equipment and compare it to the rated limits of the surge suppressor first.
/jab
1 - 15 of 15 Posts
Status
