Status
Not open for further replies.
1 - 7 of 7 Posts
Has anyone installed their dish on a tripod? If so where do you buy it or how do you make it.
My friend has to install a dish inside her apt facing a window and she thinks the pole in bucket contraption is too ugly for a living room.
She only wants HD programming so she only needs the 18 inch Dish.
Eram
Try looking up some independent DirecTV/DISH Network installers/resellers in the Yellow Pages. Chances are they'll have portable mounts or tripods for sale. Some RV and travelhome owners use them instead of permanent mounts, so many resellers stock them.
I installed a tripod based elliptical dish to get DirecTV from my apartment. But, mine is installed on my balcony.. a tripod will be quite large for inside an apartment.
I got my tripod at Radio Shack. It is intended for a rooftop antenna. If she is using the oval dish, the 1" mast that Radio Shack sells should work fine. But, the elliptical dish needs a bigger mast. I used 1.25" electrical conduit from the local hardware store.
I put some info/pictures here: http://weaselworkz.com/hdtv/balcony/index.html
She should go with one of the flat panel dishes you can purchase for window panes. A friend has one and it works well. Winegard makes them, I believe. If www.starkelectronic.com has them, they'll undoubtedly have the best price.
[This message has been edited by PF (edited 08-09-2001).]
1 - 7 of 7 Posts
Status
