Status
Not open for further replies.
1 - 2 of 2 Posts
· Registered
I received the 752 upgrade today and immediately noticed a problem with the video on my VGA display (it's my HD display for now.) The picture has a very purple cast. Upon breaking out my 'scope I found that the blanking level for the green signal was close to 0 volts, but the blanking level for the Red signal was +1.5 volts and the blanking level for the Blue signal was about +2.0 volts.
You video guys will recognize that a negative green shift makes for a purple picture.
Is anyone else seeing this on a VGA display with the new upgrade?
· Registered
Discussion Starter · #2 ·
After a few power off/power on cycles, the problem appears to have gone away (or my VGA display finally got used to the video.)
Sorry for any inconvenience!
1 - 2 of 2 Posts
Status
