I tried searching for this issue, but really guys, that 80+ page thread is out of hand, so I'll just post here.
I have a 16:9 TV, so I set my TS160 likewise, and I like my 4:3 content to be viewed with bars on the side (burn in is not a problem), so I set the TS160 to put bars. I DESPISE, CONDEMN, and WILL not watch a zoomed or stretched image. It makes my head hurt.
Here is where the problem occurs. When viewing SD TV, the right side of the screen is being lopped off, by about 7%. The stock indices on certain channels are getting cut off, MSNBC was one of them, I think. A whole number and the little green arrow (red recently) is cut off.
Normally this wouldn't bother me, but it skews the whole picture. The size of the image is 4:3, (actually, the image is a litte wider than 4:3, the bars are narrower then when my HD channels broadcast the bars.) and since 7% is being wacked off the right side, everthing looks a LITTLE out of 'ROUND'. Like when the HBO logo comes up on HBO, the 'O' is more like an oval. Faces don't look quite right either, they look a little fatter than they should. I hooked up my other Sony receiver, as it only outputs 4:3 and everything is fine, and the bars produced by my projector are wider than the ones being produced by the TS160, when I go to Normal mode.
OK, that's the problem, but here's the kicker. When I press guide, and the little screen at the top left shows the current program, it's PERFECT. I can see the whole market indices, with daylight to spare. And the faces are nice and ROUND. The little screen is about 14" wide, and about 1" of that little screen is being cut off on the full screen version, so I figure that's about 7%, on one side.
I tried adjusting using the Monitor Setup, but all it does is moves the entire screen left are right. It doesn't actually adjust the displayable image, like it does when adjusting HD content. HD content looks great and the aspect ratio is preserved.
Has anyone heard or seen this problem?
