Hello all i have a couple of questions to help me on my way in backing up my blu-ray movies.
First off do i need to change the FPS to 25fps?
when i took out the 5.1 surround TsMuxer goes through fine, i left in:
"AC3 bitrate: 192kbps sample rate: 48khz channels 2"
now there are 2 of these in there? i do want 5.1 digital surround but what is the channels 2? also there is:
"PGS presentation graphics stream #0" there are 2 of these #0 and #1 what are these?
When i changed the video output to DTS-HD (i took out the channels 2) and ticked
"downconvert DTS-HD to DTS" at 96.6% i get an error message:
"reading buffer overflow. possible container streams are not synchronized. please verify stream fps."
does anyone know why?
I do not have a hd av receiver so i cant play hd surround but this would downconvert to normal DTS like it says?
last bit:
on the out put section in tsmuxer i was told to use m2ts, but you guys/girls are saying use "create blu-ray disc" whats the difference? also i'm stuck on the burning part, i know how to create a iso image using imgburn, but again some of you are saying no to this? i want the best out come visually and audio possible so whats the best way of getting this?
I was told iso file then nero to burn? but imgburn can burn iso files why not use this?
thanks for your help (if i get any)
last bit:
