Status
Not open for further replies.
1 - 1 of 1 Posts
· Registered
For those of you having problems with horizontal and vertical sync on Panasonic STB:
I finally created a circuit board to correct the sync problems that Ron Jones discussed in this post:
http://www.avsforum.com/avs-vb/showt...769#post973769
The Panny box puts out a sync level that has a DC level shift. From my observations on a scope, the level shifts positive to the point where several projection devices may lose sync.
I am using a Proxima DX3 DLP projector (1024x768) and it would not sync to the Panny STB no matter what I tried.
Ten or fifteen circuits and several hours of scope time later, I finally found a circuit design that synced up to my DLP projector.
I have tested it with great results on 480P and more importantly, 720P.
The only drawback I have seen is that it appears that a few lines may be missing, due to the 768 line native resolution of the Proxima.
I will put in a few hours of viewing and tweaking and check out the results.
I am impressed with the RGB output of SDTV, DTV and HDTV from this box. The guide is another story!
Larry Cobb
1 - 1 of 1 Posts
Status
