Cincinnati/Dayton Area TV fool Corrections (and/or comments)
Both Current+post Transition :
WWRD-LP (analog) is Currently shown in TVfool with their old ch 55 facilities.
They moved to 32 about a year ago, Using the Licensed facilities which show up for them, currently on 32 in FCC's TVquery :
http://www.fcc.gov/fcc-bin/tvq?state...&slon2=&size=9
Their old, Ch 55 facilities no longer show up in TV Query, so maybe this one is on 55 in TVfool due to an old override ...
Post transition Only - Analog :
this is a bit of a odd/unusual one :
W66AQ Dayton is shown on 66. If I recall correctly, I think stations on ch 60~69 must vacate by analog shut off.
W66AQ has a CP/authorization to move to channel 22 (Callsign change to W22DE) for post-transition -- via repurposing Current WKEF 22 (analog) facilities.
I assume Since WKEF analog is currently on 22, the CP is not easily "apparent" via TVquery. However, there is some info available on it here :
http://fjallfoss.fcc.gov/cgi-bin/ws....ion_id=1125566
Unfortunetly, The only place I know (didn't check the CDBS "downloadable" files) of which has the Engineering data for the CP is the Form 346 app for this CP, available here (Note: Link requires a PDF reader) :
http://fjallfoss.fcc.gov/cgi-bin/ws....&fac_num=11203
And the authorization available via the "get authorization" link available at page at first link above has the Callsign for the CP as "W22DE" , and some abbreviated engineering data (but not info on the DA)
It's just a wild guess, but I'm thinking the "info" on W66AQ on channel 22 (and the W22DE callsign ) won't pop up in TV query/CDBS in the "usual" way until after analog shut off AND until FCC (at some point) removes WKEF 22 analog records (and presumably all other Full service analogs after they go off air 2/17/09) ....
Given the lack of engineering data/"new" callsign for them for 22, Other than on app and in the authorization, I'm not sure what(or if anything should) can be done with this one for TVfool until it "shows up" in CDBS or TVquery .. Which will hopefully be sometime soon after 2/18/09 ... Just a "heads up" regarding this one, FWIW ...
Post-Transition Only - Digital :
The following are currently showing up in TVfool per info which matches Maximization "application" Data at TVquery rather than these stations current Post-transition CP's -- Maximization applications which have yet to be approved or denied or acted upon by FCC --Of course if these are approved at some point and become CP/CP Mod, these will be fine, but there is no indication presently, AFAIK whether they will or won't be approved.
DO note
All of the stations I checked end up on "this list" which A), Are *not* changing channels post-transition, and B). have both CP's(or licensed facilites), and Apps which have not been acted upon by FCC as of yet, and C). are currently shown on TVfool per the (unacted upon) application data instead of the currently accurate post-transition licensed or CP/CP mod info -- So, I expect this may very well be a widespread issue effecting other stations with this same situation :
WHIO-DT 41 - I noticed this one because Xmit(KW) Column indicates 1000KW ERP for my plot/receive location, which would indicate non DA, instead of the Current DA, which is also the "current" authorized Post-transition facility. (Current TV fool correctly indicates they squirt 36.63Kw ERP in my direction) ... TV Query Link for them here :
WKOI-DT 39 - Noticed this one because ERP shown is incorrect for their current 370KW CP DA for my location ..555KW ERP is shown in TVfool, which would be correct for my location only for application(not yet approved) File # BPCDT-20080618ATM , 600KW ERP with DA ..
http://www.fcc.gov/fcc-bin/tvq?state...lon2=46&size=9
WSTR-DT 33 - This one is a little difficult to tell for sure given some of the different apps/facilities specified aren't that different ... However, for my location, 711 KW ERP is shown in TV fool, which per my math (closest I could get "manually" calculating with the relatvie field values shown in 10 degree bearings) would indicate this could probably only be the 1000KW APP, rather than the 900 KW ERP (current) post-transition CP :
However, there is one station I checked -- WBDT, Dayton Which is the only one in area currently For which the following(currently) is true : A). They are Changing channels post transition(from 18 to 26) B). have both a Post transition CP (50KW ERP on 26 ) and C). has other maximization App(770KW ERP DA for 26) not yet approved/acted upon which currently pops up on TV query -- And, in this case Unlike the stations listed above(all in area which aren't moving and have both Licensed facilites or CP's AND "unacted upon" maximization apps) the TVfool post-transition plot for WBDT-DT currently correctly is using the Current, Post-transition CP Data ...
Everything else Looks good ...
As allways, Thanks Andy!
