I hate seeing WBRA-DT on equal footing with other stations in the listings even though there's so much noise on low-VHF that it literally doesn't decode more than 90% of the time, or decodes in such a broken up manner as to be unwatchable. And that's with a dedicated low-VHF antenna at the very highest point on the mast. Whereas just about any UHF antenna maxes out the meter on the local UHF signals.
I hope eventually some decision is made about this, because low-VHF in reality doesn't match up to any predictions I've seen anywhere.
- Trip
Originally Posted by andy.s.lee /forum/post/14806627
No, because the analysis is done for signal strength "in the air". The VHF "penalty" that you're talking about is usually applied "after" this point to account for lower antenna gain, lower tuner sensitivity, and higher ambient noise at VHF. If you want to account for additional VHF signal loss for these factors, you need to subtract the appropriate values from the "starting" Noise Margin value to see what final NM you end up with at your receiver.
It is true that automatically including a frequency selective adjustment factor might provide a more "fair" comparison across all channels, but this really depends on each person's setup and link budget parameters across all channels. Diving into this next level of detail is opening up a huge can of worms which we're not ready to deal with yet.
- Trip
