I have an 55" XBR8.
Two scenarios:
1) TV mount - Basically:
-My wall has panels on it from the ground up to about 3 feet. On top of these panels, is a horizontal trim line, which extends about 3/4" away from the wall.
-I would like to hang my TV at eye level (just as if the TV was sitting on a typical tv stand - the same height).
Are there any specific TV mounts that accommodate for this? I want the TV screen to be 90-degrees to the ground. My plan was to find a TV mount (with long vertical rails downward) that I can mount to the wall a little higher than the horizontal trim on the wall, and have the vertical rails on the mount extend down further (passed the trim), instead of the vertical rails being "symmetric" and equal in length. Has anyone experienced this before? I cannot seem to find the right mount for my situation.
2) TV Stand
-I have a large center speaker, about 2 feet wide, 1 ft in depth, and 1 ft high.
The TV resting on the stand is not the problem. The problem is fitting my center channel speaker. I cannot find any nice stands that fits my situation.
Anyone input from anyone? Thanks
Two scenarios:
2) TV Stand
