Status
Not open for further replies.
1 - 7 of 7 Posts
I will be buying a 50" to 60" 1080p HDTV this fall and I am researching TV stands.
I currently own Rocket Speakers with a "Big Foot" center speaker (RSC200) that comes in at 46 lbs - 12" high and 26" wide! I am not having any success finding a TV stand where I can put the center speaker "in the center" of a stand. Most shelves are only 8 or 9" tall. Then besides the center speaker, I need shelves for the components on the sides.
Does anyone have the "Big Foot"? If so, what type of stand are you using?
I have been looking at Racks & Stands, Techcraft, Ikea, etc.
Any suggestions would be appreciated. If I can't find one online, I guess I'll see if a local cabinet maker can build me one. :eek:
You may want to go over at the forum at AV123 and do a search. I know member Brucer had some pretty good ideas for Bigfoot T.V stands.
I also own the RSC 200 and will be getting a 60" DLP soon and wil be running into the same issue. Good luck.
Discussion Starter · #3 ·
Thanks for the tip. I will check them out.
BTW, I am very pleased with the Rocket Speakers. I am not an audiophile, but my jaw dropped when I heard them.
Hi,
I just bought a Toshiba DLP at Costco last week and have a similiar center channel (Klipsch RC-7). I actually bought a white wall mount for a TV 17-23" I think it was and it looks great!!. I hope to post pics in a few days. I am very happy with it. I bought the stand at Best buy for around $75 normal retail. I looked at quite a few but this works out perfect.
Hi,
Click on my name and then look at my phot gallery. So far it has worked great and fit perfect. Hope it helps.
Mark
Discussion Starter · #7 ·
Norcuron,
Thanks for the reply. Nice looking setup.
I have decided to have a local cabinet maker build a custom cabinet for me. Basically, it will have about 28 to 30" in the center for the "bigfoot" and flanked by two smaller adjustable shelves on each side.
1 - 7 of 7 Posts
Status
