Hello guys. I did some search on the forum but can't to find any information that related to my issue.
I bought a wall mount for my 52' LCD the problem is the width of the wall mount is only 20 inches wide. My spacing between the stud is 24 inches. Any suggest on how I would install it? No I can not return the wall mount.
I was thinking to go to homedepot and get a piece of plywood and cut so I can screw it on the two studs and then put the wall mount on the plywood. Is that strong enough to hold it?
