TVIX LAN Connection issues
428 Views 0 Replies 1 Participant Last post by  sheggsl
I recently got a TVIX 5000u based on forum recommendations. I seems to work fine, plays internal disc files faultlessly, however I've not being able to get it to connect to my Local network. I've played around with the Network settings in Set-up to no avail. My network currently consists of a Laptop, HTPC and Buffalo terrastation, all of which can see and communicate with each other no problem.
As per the manual I've selected DHCP and set the network disk to NFS and IP address to the same as the 3 items listed above with no joy. I think my router detects the TVIX, because the port that the TVIX is connected lights up, once the TVIX is powered up.
I'm really starting to get frustrated with these Network streamers as they all appear to be quite problematic. I had moved from a Snazzio which had a streaming speed of a snail on a gigabyte network, to one which doesn't even connect.
Any useful help or advice will be most welcome.
Status
Not open for further replies.
1 - 1 of 1 Posts
1 - 1 of 1 Posts
Status
