1 - 3 of 3 Posts
I have my m4k hooked up to my receiver with coax. I would like to have my receiver do the amplification, so how do I set the tvix unit to output a "line out" or fixed volume? (ie. not amplify the audio track's volume itself in the digital domain)
If there isn't a "fixed" or "line out" option, what volume 'number' would correspond to this?
Hi,
I beleive that 25 (or similar) is the same as no processing.
That is the value just before the volume bar turns red. Tvix wrote somewhere that they recommend to not use the internal digital amplification and that is why the volume bar turns red when it starts.
/J
1 - 3 of 3 Posts
