1 - 20 of 71 Posts
Looking at subs for my bat cave build. Dimensions are 15' wide x 20' long and 8.5' ceiling. Im torn between picking up two new 12" budget subs vs one better 15" sub. Was looking at getting a pair of Lava LSP12's for $340 total, but found a used Velodyne DEQ 15R for around $500. I know the Velodyne is better, but if I spring for the Velodyne, there's pretty much no way I'd be able to pick up a second one down the road if its even needed. I will guess 90% movies and 10% music. Which route would be better suited?
Opinions??
Sent from my Galaxy Nexus using Tapatalk
Banned
Originally Posted by madspeed  /t/1498287/two-12-vs-one-15-need-help-deciding#post_23916932
Opinions??
Buy two Lava LSP12s, download a freeware copy of REW and keep your mind open to a third Lava LSP12, in the future.
(subwoofers do not play and get along well with a room's acoustics. the only way to see a room's acoustics is through a measuring program like REW. buy two LSP12s, use REW to help properly dial them in and decide later if you should add a third LSP12 to aid in smoothing out measured results.)
Discussion Starter · #3 ·
should note that my original budget was about $300, but could spring a bit more for a higher quality unit if needed. I prefer the thought of the two Lava's. THX
Originally Posted by BeeMan458  /t/1498287/two-12-vs-one-15-need-help-deciding#post_23917067
No. Get one 15" (or DIY). And in 6 months or so, if you have a little more money, you buy/build another. End result will be so much better.
I'd build twin 18s myself (or better, quad 18s).
Premium Member
Velodyne DEQ 15R
- 15" driver
- 750W RMS
- 32-120Hz +/-3dB (?! - that seems like poor extension for a 750W RMS ported sub with a 15" driver)
Lava LSP12
- 12" driver
- 250W amp
- 24-400Hz +/-3dB (LFE)
I'd go with dual Lava subs. You might lose out on overall output vs. a single Velodyne, but you'll still get good output, you'll get smoother FR across the main listening position, and - according to the specs, at least - you'll get better extension.
Originally Posted by nexxest  /t/1498287/two-12-vs-one-15-need-help-deciding#post_23917139
If you read the op it say if he bought one 500.00 15" sub he would NOT be able to purchase another down the road. Not move on back to DIY section where you belong
For $465 I built the powered sealed 15" sub shown below. It's performance is outstanding. You need some glue and clamps and something to cut a hole to fit the plate amp. A little paint and a couple of hours of work will get you something you would pay over $1000 to duplicate from a manufacturer. Something to think about.
Madspeed - if you can swing a bit more money I really think you should give a strong consideration to the Rythmik LV12R. I believe is $587 shipped and will get you usable output into the upper teens hz, its -3db point is 19hz. Its probably the best bang for your buck at that price point....... IF at some later point down the road you have enough money to purchase a 2nd LV12R I think that would be a killer sub setup in your room. FYI I have 2 Outlaw Audio LFM-1 Plus subs (similar performance to the LV12R) in a room 21' X15' X 8' and they sound amazing.
Discussion Starter · #10 ·
Originally Posted by FMW  /t/1498287/two-12-vs-one-15-need-help-deciding#post_23917203
Not totally opposed to a DIY, although I'm obviously not that knowledgeable as to what exact pieces i would need to buy to accomplish this. I couldn't certainly follow ones proven shopping list...*HINT*
Banned
You can't smooth room modes with one sub.
Originally Posted by Bill Fitzmaurice  /t/1498287/two-12-vs-one-15-need-help-deciding#post_23917794
No but you have great bass anyway.
Originally Posted by madspeed  /t/1498287/two-12-vs-one-15-need-help-deciding#post_23917423
Call Parts Express. I don't see it on their web site but they normally have a package deal with their 15" Ultimax driver and a sealed cabinet kit made and cut for it. I used the Yung 300 watt class D plate amp. You will want some rubber feet, some stuffing, some small weatherstripping to seal everything and some hookup wire. All of it is available from PE. Add some sealer and paint and you're good to go. They have less expensive drivers but the one I used and show above is the Ultimax. It has a stiff nomex cone that you can literally hit with a hammer so I don't mind the thing being exposed. The final product weighs 85 lbs and provides clean, tight bass notes and more than enough power to shake my 18' X 20' room. You can always add a second one later if the mood strikes you. I'm not likely to do that. This unit gives me all the bass I need.
Room modes only matter if they occur at the LP, so depending on the room there may not be a problem.
  • Like
Reactions: steve nn
Banned
Originally Posted by FMW  /t/1498287/two-12-vs-one-15-need-help-deciding#post_23918439
Parts-Express.
I do not need encouragement to go (AIY) assemble-it-yourself.
Banned
Originally Posted by Kini62  /t/1498287/two-12-vs-one-15-need-help-deciding#post_23918440
True, there may not. But there may, and the OP won't know until it's too late if he goes for one fifteen.
Maybe I missed something, but not sure why all this talk about 12" vs. 18". If my math is right, the room is 2,550 cu ft. I would just get an SVS PB-1000 for $499 shipped and be done with it (b-stock comes in at $449). The PB-1000 reaches 99.8db at 20hz and is flat up to around 200hz.
Where is shadyj when you need him to push this 15" Dayton sub kit? http://www.parts-express.com/pe/showdetl.cfm?partnumber=300-770
That one is $339. Get one now, and next year if you feel like it, add another
Well you certainly don’t want the Lava’s imo. The single LVR would be all good with another in mind down the road as the PB1000 would. A DIY option you might consider would be the 12” SDX. A very high quality 40 pound high Xmax driver. http://creativesound.ca/pdf/SDX12.pdf You have a choice of 4 different options.. ABCD http://www.creativesound.ca/ . I would stay away from the 15” sealed option being spoken of myself http://www.parts-express.com/pe/showdetl.cfm?partnumber=300-770 , especially in a room that size. No dsp, room gain, power nor Xmax to say anything down low.. just my opinion
1 - 20 of 71 Posts
