Status
Not open for further replies.
1 - 2 of 2 Posts
Running ati 9000pro in clone mode and video Apps (power dvd,power vcr,Dscaler) will only play on primary display. Secondary will show desktop and control panel for Apps but what should be video is blacked out or pink. Can switch it between the two but will only show on one at a time?
The other thing is 3D Apps no longer have standard Resolutions available,other than 640x480.Some games show the 960x540 that I have set-up for my RPTV but none of the standard 800x600 , 1024x768 etc. All standard resolutions still show available in ati control panel?
RPTV is RCA D52W20 via DVI-D
How is it going so far with you monitor resolution situation? I have a D52W20 that I drive with a ATI 8500DV from the DVI output. It works so far. I use PowerStrip to run my D52W20 in 940 X 540, 32 bit, 60Hz. I want to increase the resolution. What resolution are you running?
1 - 2 of 2 Posts
Status
