I just picked up a 3545V/37 DVD/VCR combo and a Panasonic TC32LX85 TV, my first digital for each. With my several year old Panny VCR, I can hook the (Bresnan) cable to the VCR and from there to the TV - analog or HDTV -in effect putting them in parallel, and it runs fine. If I want to play a tape, I turn on the VCR and push play; stop reverts back to the TV. The limit is that recording can only be done on the same channel as the TV is set to, which isn't a big deal for me.
The problem I'm having with the Phillips is how to - or whether - it works with with this method of connection (Panny VCR disconnected). So far the tape doesn't play on the TV this way or by adding red/white/yellow RCAs. The only way I've been able to get a VHS tape to play is to hook up the RCAs and switch the TV's input to Video 1 (haven't tried recording yet). That doesn't seem very efficient. Is that really the only way or am I missing something?
A second question is what I should expect in terms of noise output from the Phillips in idle (on, not playing). It's not buzzing, but with the TV off there's a definite low motor-like sound; i.e., it's not silent like the Panny VCR. Also it looks to me that when the cable is hooked thru the Phillips, the SD channels are degraded a bit vs. a straight-to-TV cable connection. Is that normal? If it's happening with the Panny VCR, it's too subtle for me to tell for sure. I won't be getting an HDTV cable box until later in the week. Thanks.
