Status
Not open for further replies.
1 - 7 of 7 Posts
· Registered
I'm building my dedicated theater room with two rows of seating. My question is should I put one rear speaker on the side of each seating row for both left and right surround channels ? Just to clarify, this would be two speakers for the left channel, and two for the right. Or should I just stick with one speaker per surround channel. BTW my amp puts out 100 watts per channel. and I'll probably use polk rt55's to match my mains.
· Registered
You'll,get other opinions on this (like anything else),Doc,but my answer
is yes.Yes,for sure if you're using
direct radiating speakers.I don't
think I'd be inclined to use four
dipoles.I've been using four surround
speakers for several years. I bought
the original Atlantic Technology 250
series,except the sub (yuk),which
came with less-than-full range dipoles.Shortly there after I got
Dolby Digital and needed full range
surrounds.Not wanting to replace the
lot,but wanting matched sound,I bought
two more of the front LR speakers for
surrounds.I put the dipoles on the
back wall for an extra set.I usually
run all four speakers,occasionally I
turn off the dipoles.I'm soon to
experiment with the dipoles as the
rear EX surround channel.Maybe you
need six speakers for the rear,two
more for EX,ha...! Denon reccomends
dipoles on the side and full-range
(for music) in the back,surrounds.
My room is less-than-optimum with
an alcove on one side,so dipoles on
the side are out of the question any
way.The oposite has worked for me.
I like the way the full-range side
speakers give me a directional cue when an effect flys.The dipoles in the
rear sort of fill in the soundfield
with that cloudy kind of sound they
make.If my experiment goes well,my
dipoles may become EX permanently.
Well that's my three cents worth......
Ms. Bitchlist
· Premium Member
I'd imagine one rather obvious missing fact here is "how far apart are these two rows?" If these are not 10' (or better) apart, you don't want two "rear" speakers astride each row ... whether direct radiating or dipole. You'll end up with a confusing and fatiquing listening environment.
If you're really hot on the trail of 4 sets of "surrounds", you can have a pair on the sides and a pair on the rear walls IF your surround processor supports this environment. By "support" I mean the signal to the sides and rears is different and, at a minimum, you have the ability to set the delay and reference SPL of *each* speaker independantly (which disqualified the Denon day one).
D. Erskine
DEsign Cinema Privee
www.DEsignCinema.com
Imagine what you could do, if you could do all you imagine.
· Registered
Dennis ,are you recommending the EX
setup? Or 4 speakers without? What
do you think about EX? I'm not so sure
I'd bother with it if I didn't have
the extra speakers,but you never know
I might like it! Getting the four
speakers now would leave an easy upgrade path wouldn't it,even if no
EX setup is used now? I rather like
my extra surrounds,especially on loud
action films.I like with and without.
And I have a set of Paradigm speakers
with dipoles which i like very much.
I can't even decide wheather I like
full-range surrounds or dipoles best.
Dennis what kind of back speaker do
yo like for EX,dipoles or monopoles?
I'm sure you proably like dipoles on
the side,right.....
Ms. Bitchlist
· Premium Member
I wasn't thinking so much of EX as I was 7.1 systems such as those from Meridian, JBL, Lexicon, and Citation. (which are now all EX capable).
As to dipoles side and/or rear. I have a preference for dipoles. That being said, however, the real choice will be driven by the processor you purchase. For example, JBL Synthesis (using the Lex MC-1) must use dipoles because the steering logic used for their 5.1 and 7.1 modes relies upon the unique characteristics of dipoles. On the other hand, Meridian's processors have all been built (and code written) with the presumption the sides and rears will be direct radiating (monopole) designs.
D. Erskine
· Registered
I read a review of the Circle Surround
unit that recommended monopoles in back....Have you set up many EX systems and with what configuration?
That would go with this thread.I'm
renting now,but when I'm not.....
It could be me building,will be.....
Ms. Bitchlist
· Premium Member
I can't say that I've set up alot of EX systems. I can say that I've set up alot of 7.1 channel systems (some of which may have been upgraded to EX by now).
All the monopole side/rear systems have been exclusively Meridian and have used Meridian's DSP speakers. (I had such a system myself.) All the others have been dipole based.
D. Erskine
1 - 7 of 7 Posts
Status
