Well, the sound will lag 35 or 60 feet behind, if that's OK with you?
Just kidding! The delay would be umptillionths of a second, don't worry about it. Do get well shielded cables-50 and especially 75 feet are long runs.
Well, the sound will lag 35 or 60 feet behind, if that's OK with you?Two JTR 118 HTs. Should the two sub RCA cables be the same length? One needs either a 50 or 75 ft cable; the other, about 15 ft will do it. Thanks.
But there would be a difference in internal resistance, wouldn't there?The delay would be umptillionths of a second, don't worry about it. Do get well shielded cables-50 and especially 75 feet are long runs.
They do not need to be the same length at all. I bought different lengths of rca cable for trying out the subs in different locations throughout the room, and just kept with cables used for testing in the front of the room that were much longer than needed rather than pulling and swapping cables.Two JTR 118 HTs. Should the two sub RCA cables be the same length? One needs either a 50 or 75 ft cable; the other, about 15 ft will do it. Thanks.
The sub may have an input impedance of 10k ohms. Cheap copper coated steel RG6 coaxial cable is listed with a DC resistance of 28 ohms per 1000 feet (300m). For a 75 foot cable, that'd give a DC resistance of approx. 2.1 ohms. That'd give a drop less than 0.001 dB. I think that you'd have trouble adjusting a gain knob that finely.But there would be a difference in internal resistance, wouldn't there?
I suppose that can be compensated with the volume knob on the sub though.
