1 - 1 of 1 Posts
Discussion Starter #1
Hello Folks,
New to the forum - and just spent a ton of time reading up to try and find this issue. The only person that seems to be having a slightly similar problem has it a bit worse off than myself (at least my wireless works for a few days).
Not quite sure what's happening but I've been able to 'restore' the receiver to factory, re-apply the atmos firmare update, and re-connect my network. The router is fairly new and seems to be working fine (with regard to other devices). Even the receiver has no problems using the wireless to download the firmware updates (upon resetting the router).
Plenty of ventilation around the receiver - actually, it's almost completely exposed - so heat shouldn't be an issue. Thoughts? Solutions? Thanks!- joe sardone
1 - 1 of 1 Posts
