Morning,
Checking out prices of DTV systems. Planning to switch from DishNetwork. I've seen a special for 2 rooms for $49.99 before $50 rebate. System has dish, and two entry level receivers.
I want the Ult TV receiver. If I get the 2 room system special, then go out and buy the Ult TV reciver and replace one of the receivers is the installation easy? Just hooking cable to the back of the receiver to swap receivers? Is there anything that needs to be done from the Dish. Extra cables? etc.
Trying to get a Ult TV reciever and basic entry level receiver and installation for a good price. Can't do Minidishes (bad encounter).
Russ
Russ
