Status
Not open for further replies.
1 - 3 of 3 Posts
Can someone enlighten me about the DVD codes for the UltimateTV's orginal remote? I have a Pioneer DVD that I cannot find the correct codes to program into the remote.
Where can I find the codes for DVD? They are not in the setup guide.
Also, when one does a device search for the DVD button, it does not seem to "search" thru anything... I can only see one IR blast on my IR Wireless Transmitters instead of a stream of codes that I would expect during a "search".
Any ideas? Thanks
Tom
Hi,
Actually it should be RCA DVD Players Only.
If you have the RCA UTV remote anyway... The original Sony UTV remote doesn't have DVD functions.
Since RCA and GE are the same company you may be able to get some other DVD players to work besides RCA, but it would be trial and error.
Later,
1 - 3 of 3 Posts
Status
