1 - 1 of 1 Posts
EDIT:  Sorry, moved to official owners thread:
http://www.avsforum.com/t/1463286/official-samsung-unxxf8000-owners-thread/6270#post_24543990
Howdy,
I picked up an F8000 in November, and all is well except for an irritating symptom when using "smart app" functions... When using Pandora, PLEX, or select other applications, I will experience nominal sound and picture for a random period of time, and then the sound will become exceptionally distorted and extremely loud.  The sequence of events is as follows:
1)  Open Pandora
2)  Select a station
3)  Listen to tunes for $TIME
4)  Pandora starts a new song and the volume goes 5x and audio content becomes highly distorted
Again, this happens with Plex as well, so the issue is multi-app.  Additionally this can occur with the first song selected.  Fast forwarding to the next song fixes most of the time, but the problem will surface again at a random interval.
My setup is as follows:
TV:  UN55F8000 (software version 1119)
A/V Receiver:  Yamaha RX-V573
Connection:  S/PDIF out from TV to Yamaha (Optical direct)
One other note is that I had the TV and receiver connected via ARC for some time and the issue existed with that setup as well (as i would expect since it's the same output circuitry one would think).  I have other digital audio inputs connected to the Yamaha (SageTV HD300, Sony Blu-Ray player) and none have had these issues.
Has anyone reported similar issues, or am I the lucky first?  Just curious before/as I go to Samsung... My panel doesn't have any bad pixels or banding issues, so replacing it would irritate me (lottery).
Thanks again
/jer
1 - 1 of 1 Posts
