Hello All,
I just joined this forum and also have just started to build a home theater in our basement.
I am going the DIY route looking for deals and cutting costs where I can.
Today I went to home depot in Gainesville, GA to look at the porter cable 3 nailer/compressor combo. All the reviews that I have come across rate it as an excellent buy at 299.00 (Home Depot).
Anyway, while I was there looking at it, I stumbled across an even better deal a Porter Cable 4 Nailer/Compressor Combo CF6401 for 299.00. I priced these online and Retailed separately they would cost $1,224.08. On sale separately they would cost $649.38 and these costs do not reflect the Contractor bag, hose, nails and staples that was thrown in with this kit.
Includes the following:
6 Gallon pancake compressor max 150 PSI and two quick connect outlets.
16 GA. Finish Nailer 1" to 2-1/2" (FN250C)
18 GA. Brad Nailer 5/8" to 1-3/8" (BN138)
18 GA. N.C. Stapler (NS100B)
23 GA. Pin Nailer (PIN100)
40' X 1/4" hose with fittings attached.
Contractor Bag
2000 23 GA. 1" Pin Nails
1000 16 GA. 2" Finish Nails
1000 18 GA. 1-1/4" Brad Nails
1000 18 GA. 1/4" X 1" Crown Staples
Nailer Oil
Safety Glasses
I don't work for home depot, look the tools up on line and you will see that this is an excellent deal if you need tools to do the finishing work on your Home Theater.
Good Luck,
Steve
Contractor Bag
Nailer Oil
Safety Glasses
Good Luck,
Steve
