I need a subwoofer, but it has to meet some unusual criteria. I can spend around $500, and I simply want the absolute best sub for that process range. I will be using it for home theater only. The popular choices seem to be the entry level svs and epik subs, and they sound great, but they are not an option for my situation.
I have a friend at a retailer who can get me mainstream brands at cost. As svs and epik are buy direct to us in the US, he cannot get the low price. I need a sub that isn't from a buy-direct manufacturer, and I want the very best for a $500 budget. I can go a little over budget if its really going to be worth it.
I don't trust the opinions of the salesmen at through local vendors, so I'm putting my faith in this community instead. What should i get? Polk? Klipsch? Bic? Something else?
My setup is a humble theater in my 12x18 living room. Devices are run to a closet via the attic.
