Status
Not open for further replies.
1 - 2 of 2 Posts
i just replaced my overly noisy original unity motion fans with radio shack number 90-2508. it fits perfectly and cools well but it is so noisy i can't use it like this. do any of you unity motion folks know of a good replacement part and supplier? thanks.
levytv
[This message has been edited by levytv (edited 03-21-2001).]
Check out www.delphi.com/unitymotion There are several threads about this operation there. I had a noisy fan and found that it was the one attached to the chassis. When I adjusted it "just so" with only one screw, it was silenced. YMMV. See dealer for details. Some restrictions apply.
The button is labeled "Play", not "Pay". STOP the MPAA!
Our Silent Angels
1 - 2 of 2 Posts
Status
