Status
Not open for further replies.
1 - 6 of 6 Posts
I'm using my Sony AV-2100 to control the lt150...I used the "TV" component button and learned all the codes...it works well though it's a little awkward having to aim the thing above and behind me to get it to work. Time to run some cable for IR repeater ;)
Chris
While not directly germane, it took me approximately 15 minutes to set this up on my pronto.
Chris
Can't you just aim at the screen? That works for me from my sitting position.
Rick,
My screen would have to have the gain of the mirror in the Hubbell telescope for that to work :p
I have th pj ceiling mounted and a little behind me. Is yours in front of you which allows you to aim your remote at the screen and have it work?
Chris
My projector is ceiling mounted behind me and my remote works fine off of a 1.5 gain screen, except during dark scenes while viewing a movie.
Petey
1 - 6 of 6 Posts
Status
