Updates
308 Views 3 Replies 4 Participants Last post by  Markito
I was a Tivo owner for a few years and have moved to Replay TV. I own a 4080 unit, and for the most part like it. I particularly think the commerical advance is pretty cool ! I wish though it had some features like the Tivo like a graphic for rewinding and recording to see where you are in the buffer. Or for that matter, a smaller buffer. It is easy to get lost. I also like that if you record a show in midprogress with Tivo, it captures the show from the beginning if you happened to be on that channel when the recording started. Also, it would be nice if updates to the channel guide could be done more frequently than once a day in order to make better use of MyreplayTV.com. It also would be nice to have a general information page, like current software version, last successful update, etc
I'm sure others have send recommendations to the replay wishlist. Does anyone know if Replay will adopt any of these / send an update of the software soon ?
Chris
Status
Not open for further replies.
1 - 4 of 4 Posts
General information page is 2-4-3 Zones (from any screen).
I believe that's 4-1-1 Zones for general info.
Also pressing display while watching a show will display the time into the show in the upper right corner.
And ReplayTV has said in several interviews that later this summer they will make "MyReplayTV.com" almost instantaneous for 4K users. I hope that I am not Waiting For Godot, because I can't wait!!! :)
1 - 4 of 4 Posts
Status
