1 - 4 of 4 Posts
Just wanted to know which firmware updates I should do for the Viewsonic 8100? It appears my pj is running version 1.51. There are a couple of updates available through Viewsonic's website and I really dont know what the differnces are between 2.5 and 2.51? Which ones should I do?
1.) Pro8100 Firmware 2.5 (Discrete 3rd Party Remote Version) Size: 1MB
2.) Pro8100 Firmware 2.51 (Original ViewSonic Remote Version - non discrete Power) Size: 1MB
3.) Pro8100 Firmware Updater Program Size: 2MB
4.) Standard Monitor Driver Unsigned Size: 1MB
5.) Standard Monitor Driver Unsigned Win x64 Size: 1MB
izover4u if your remot control have 2 power botton one for 1 power and the other is 0 for off you should update with 2.5, and if you have the same power botton for on and off update with 2.51, i have these 3 bluyray movies and iam seeing them at 1080p 24Hz, try to play them after the update, other thing at video setting set to play at 24Hz not auto.
Discussion Starter · #4 ·
Thanks for your help!! got the pj updated and am able to watch in 1080p24!
1 - 4 of 4 Posts
