"As I've stated before, we're not redesigning the Marquee on this thread."
Heh which thread do you think this is
Like I said I am anal and I always see stuff no one else sees.
I woul drive the mounter vendors crazy they show us a new CRT
I pointed out defects in the shadow mask the instant I enter the room.
I have used Ehome sense the ECP came out. in fact I helped them fix one of there problems with their sync board.
They were nice to work with and gave me a free extension PCB so I could work on the cards.
I think the change from the ecp to the Marquee can not be under stated. But on the flip side the new 9500lc's we got blew up all of them they said it was a known problem but we had have down time each time one poped.
And the the real disappointment was when we ordered some 8500 to do a video wall I think it was six. Anyways each projector had different color phosphor and different gamma curves
almost impossible to match..
And the 8000 's
like the one I have at home now is sharper then the new 9500lc we got. So Ehome has there good days and there bad days but who does not. The resin I was thinking of a new neck was because I think the bandwidth can be improved a lot.
I run at 1920x1080p all the time
also I would not use any other PJ
The barco 's don't look bad but the setup seems so hard compared to a ehome
and the Sony is a joke after playing with there set up for a bit I want to rip the PJ down and take a hammer ti it?
I have never tried the NEC so I can't say.
but I do think the Ehome is a great PJ it is just that I think it could be better. I do not care how good it I the kind of person that will find a way to make it better. I never learned that saying if it ant broke don't' fix it
It is just that the design is old it was top notch at the time
but things improve over time. And there is stuff that was not around back then. If there were to make a new CRT PJ today it would be a very different system just look at monitors at that time they had just about all the same stuff, now a new one a two small PCB,s and way out performs the old monitors. Its too bad the digitals killed the CRT
[email protected] I think if there was a new design built today it would be something..
it seems the Ehome has only2 problems the HVPS and neck fails the HVPS seems to be the worst..
and the heater problem but that is easily fixed so I do not count that. It would probably be wise for the time to be spent on making a new HVPS replacement.
but that seem a bit harder . I am a video guy not a switching power-supply guy.. and the fly-back vender's are so hard to work with all they want to do is make a custom one and will not give specs on something they make all ready.
so it is hard for a small run.
I will dread the day when I have to go digital. Every time I look at a panel even the 1920x1200 LCD's all I see is that every pixel is a different color and shade. as well as I want to converge it the RGB stripes seems so bad.
like I said I was toying with with the thought.
