1 - 4 of 4 Posts
So I just bought a 47" LG LA6200 and its looking pretty nice after some calibration but I can't help but wonder if it'd be worthwhile to return it and upgrade to the LA6900? Is there a noticeable increase in picture quality or is it mainly features/design?
Nobody in St. Louis sells the 6900 so I have no way to compare them
Hi, I had both the LG LA6200 & LG LA6900 both 47" at the same time & same room & I can tell you there is alot of light bleed on the LA6900,the design is nice & as much as I liked the 6900 I had to return my LA6900 because of the light bleed,"EDGE LIT VS BACK LIT", if I were you I would keep the LA6200,even without the light bleed the picture quality & 3D was very close to my eyes,the black level just was not as good on the LA6900,so I hope I saved you sometime
Discussion Starter · #4 ·
Thanks! I did already have some trepidations about it being edge lit and my unit having no issues or complaints. After calibration the 6200 really looks pretty awesome. Guess I'll just keep it!
1 - 4 of 4 Posts
