1 - 4 of 4 Posts
Hi!
I am about to upgrade my set from:
4 x DT ProMonitor 800 + 1 x DT ProCenter 1000 + 2 x Polk FXI-A4 (Surround back)
To:
2 x Klipsch Synergy F-2
2 x Klipsch Synergy B-2
1 x Klipsch Synergy C-2
Could you please give me some advice? I am looking for "filling" the room a little more.
In terms of audio quality, is it an upgrade? My main concern is the central channel.
Hi!
To:
1) Do you have a subwoofer? What make/model is it?
If you have no sub or a weak sub, that is the first upgrade I'd do and it'd make the biggest difference in terms of "filling" the room.
Second biggest difference is the center speaker...the DT PC1000 has tiny woofers, hence you are getting tiny sound. The center does 70-80% of the output during HT, so *that*is what you are actually hearing during movies/TV. Not the front L/R nearly as much.
2) Are you in the US, or Canada? Location will determine what's available and for how much.
3) What's your total budget maximum?
Discussion Starter · #3 ·
Thank you for answering!
My Receiver is a Denon E400. I forgot to mention it too.
Yes! It is a Polk PSW111.
Unfortunately I am not. I bought my system while living in the US. Now I am living in Brazil.
It is R$3700. I have found a guy selling the used Synergy set by this price.
The Brazilian "ebay" is this: www mercadolivre com br
But overall, is it a good update? The price sounds good for our market... (importing is complicated... Speakers are too heavy)
You may need to use your receiver's EQ to tame the treble on those Klipsch, if you experience listening fatigue...but it will be an improvement over the Def Techs, yes.
1 - 4 of 4 Posts
