Hey
I currently have an HTIB setup consisting of an old Panasonic receiver with 5.1 and 5 little satellite speakers with 4 inch woofers. I've attached the spec of the speakers as per the manual.
I want to upgrade to a Denon X4000 receiver and also upgrade the speakers but my current budget is limited. I was thinking of upgrading only the front speakers (LCR). I will go with a DIY solution, a kit from DIYSoundGroup, either Cinema 8 or Special 88 or Cinema 10.
I could then use 4 of the old speakers as surrounds in a 7.1 setup for a while.
Do you guys think the satellite will get drowned by the bigger front state ?
The LCR will have at least 98db sensitivity while the old satellite are at 81db.
Thanks for the input.
