Status
Not open for further replies.
1 - 13 of 13 Posts
· Registered
Yes, we were watching TV during the hurricane last night. There was a power surge and my Sammy DLP responded with the 3 blinking light sydrome. I unplugged it right away and when I plugged it back in this morning, everything was working OK. This made me think that I should not be risking my $3000 TV like that and maybe should invest in a UPS. Can any of you let me know what kind, if any, interruptible power supply you have your TV plugged in?
EAF
· Registered
I picked up a 500VA UPS from Staples for $10 after rebate a couple of weeks ago, it was plenty for my Panny PT-50LC13. I was worried because my set has a fan that goes for about a minute after you turn the set off. I haven't tested how long the tv would last on the UPS alone, I bought it just in case the power went out when I was watching so I could turn the tv off. I don't plan on using it for any other reason than that.
· Registered
Lol, no, I paid $40 and am waiting for a $30 rebate check. I deal with rebates a lot and Staples is by far one of the best companies in terms of dealing with rebates. CompUSA being the worst.
A decent UPS probably costs anywhere from $30-50 or so. I just happened upon a good deal.
· Registered
A UPS for safe shutdown during a power loss is important, but they are a poor choice for spike protection, IMHO of course.
Please read the link in my signature, which is the core of the rather lengthy thread jdmoser referenced.
· Registered
Im concerned about the asfe shutdown issue, but I dont know if the 350va UPS is enough
· Registered
I'm running a 500va APC UPS on mine and I have a HTPC, a DVD, a VCR, a CD player, and a Dreamcast plugged into it. Had them all powered up tonight at the same time with no problems.
I had a power 'brownout' last week and I got freaked about the TV. Decided I had to do something for my own piece of mind even if it doesn't save the TV :D
· Registered
Hi Floks
I just got my 1st piece of electronics I care about and I need to run it most of the time. Its DVDR with a clock that dies after the power is off more than 3 seconds. The DvDr acts like its the end of the world while my computer just seems to do a hard boot after the same outage. I have the DVdr pluged into a surge proctector but that does not help the clock.
What kind of UPS doI need to buy? How much should I send ? Can / should I buy it at a computer store or a hardward store?
· Registered
I'm using a Tripp-Lite SmartUPS 550VA with my HLM437W; it includes surge protection and a line conditioner.
Before I got the UPS, one of the power boards inside my set blew because of the huge blackout we had. :(
1 - 13 of 13 Posts
Status
