1 - 2 of 2 Posts
I'm in the very beginning stages of setting up a wired home network with a media server that will probably run unraid.
My work has a tired, old UPS that I can have. I would need to replace the battery so wanted to check with others to determine if it is worth the expense. It is an APC SU1000RMNET with APC AP9606 Web/SNMP Management SmartSlot Card. Specs on the UPS can be found when you google "APC SU1000RMNET" (I can't post links yet). A new battery looks like it will run me about $80 depending on shipping costs.
Is this worth using? I'm looking for a UPS that will shutdown my computers when a power failure occurs.
thanks for your help!
UHD Addict
For only $80 for the battery it sounds like a good deal. What I just read about the APC SU1000RMNET shows that it outputs a sine wave too.
Although I've been running my electronics on UPSs with stepped since wave output for the last decade with no issues either.
1 - 2 of 2 Posts
