Originally Posted by Ross Ridge /t/1418816/upscaling#post_22192560
I don't like the quality of my receiver's (HTR-8063) conversion of analogue sources to HDMI so I also have a component cable connected from my receiver to my TV. In general it will depend on which you think does a better job of handling the analogue signal, your receiver or your TV.
It shouldn't make much difference whether you bypass the receiver or pass component through it. If you only have one analogue video source then you might as well bypass it to save a cable. If you have more than one, like in my case, then I'd pass it through the receiver so you don't have to switch inputs as much.
I guess I am not making myself clear enough...
A lot of people are complaining about the AVR to display ANYTHING or display VERY POOR with the following hook-up:
HDMI-in from TV to the AVR's HDMI-out.
Xbox 360 component cable to AVR's component-in.
Just
two cables...no component monitor-out from AVR. Letting the receiver handle the component-in and passing it through the HDMI-out to the TV.
Is this a problem of the HTR6063? Or can this be resolved by a firmware update or a change of settings somewhere. I have no desire to purchase a new system if this problem truly exists...
