Status
Not open for further replies.
1 - 2 of 2 Posts
I got this remote control last night and it works very well with one exception. When I try to turn the volume up or down on my TV (Panasonic) it increases/decreases by 2 or 3 numbers. Normally, I'd expect to go by 1. If I press the volume button very quickly it works OK. Did anyone experience this behavior or is it only my remote control that does that? Should I return it to the store and get another one?
First try a reset of the TV device:
1. press TV
2. press and hold SET for two blinks
3. enter 9-9-4
4. press TV
5. press TV again
If that doesn't help, try using the advanced codes volume, which are 213-UP, 217-DOWN
1. press TV
3. enter 9-9-4
4. press SET for one blink
5. enter 2-1-3
6. hit VOL UP key, repeat for DOWN
1 - 2 of 2 Posts
Status
