161 - 180 of 350 Posts
My MX-990 has just started to do something odd. When I put it back in the cradle it is rebooting itself instead of just starting the charge.
Has anyone else seen this?
I've seen that once - could be a very low battery level?
My battery never really gets low since it is always in the cradle when I am not using it.
Interesting - have you tried reloading the program?
I am on with URC tech support now. Let’s see what they say. Reloading the software is definitely an option.
The only thing they could come up with is the battery so I will replace it. Now I have to find one that fits.
Found this:
Amazon
Also you might want to check with Surf Remote:
http://www.surfremotecontrol.com
When I asked tech support if the MX-990 battery was the same as the MX-980 they told me no. I was transferred to the parts department and they told me that the batteries are the same so I ordered the one you found on Amazon.
I will report back once I get the battery.
I am getting close to the point of getting rid of my MX-990 and going with the different manufacturer. I like the remote but most of the time I cannot get my computer to recognize it. I have been trying for an hour now but it doesn't show up in device manager and complete control doesn't see it.
Sounds like a bad unit - are you out of warranty? When I occasionally get the device not recognized, I remove the battery for several seconds (at least 15), force a reboot and then it's recognized. I do not connect through the charger but with a USB cable. I only use the charger for charging.
I have had this unit for 1.5 years and have glitches in connecting since day 1. I had similar issues with my MX-980. The MS mobile device connection process is really bad. With the Sept 2017 Windows 10 update they disabled portions of it.
Right now I can run the WMDC but I can't connect my 990.
I connect using a USB cable from the remote directly to a motherboard-supported USB input. If I open Windows Settings / "Bluetooth and other devices", it shows up under "Other devices" as URCHID.
Thanks for all your help.
Let me see where mine shows up.
Where did "URCHID" come from? Is that what you named the remote?
No, it must come from the device's base programming.
Which windows driver are you using?
Just the default MS device. I'm on Windows 10 PRO x64 version 1709 build 16299.192, up-to-date.
Maybe my remote is messed up. It shows up in the device manager in a weird place and even if I assign it a driver it never shows up in the windows mobile device center.
I never use the Mobile Device Center. In fact I avoid anything with Mobile in its name :)
What is the weird place it shows up in?
Other devices / network controller
