Status
Not open for further replies.
1 - 2 of 2 Posts
Hi ,
We are group of 4 student of California who are working on a multimedia installation.
We are getting ready to finish our project and put the whole installation
together. We already have a parabolic screen, however, it is covered with grey carpet and we need to find a suitable white cover that reflects well for the projection. Since the screen is fairly large (7feet by 12 feet plus) we are looking for a cover that wouldn't have a seam in between.
Please suggest us some idea of what kind of fabric is suitable for our screen and from where we can get it (cheapest one, we are poor student can't afford the expensive one :)).
Lax
If your using a digital projector use a flat screen with any covering you want.
If your CRT, pull off the carpet? and paint with liquiscreen or digital white goo for good 1.5 gain performance. Otherwise just paint with good white flat spraypaint and have good 1.0 gain performance.
1 - 2 of 2 Posts
Status
