Status
Not open for further replies.
1 - 4 of 4 Posts
Discussion Starter #1
I am having some audio problems, and am in need of some suggestions as to what might be causing this. It would not normally be urgent, but I am having a superbowl party in about 7 hours and don't want to have to watch HD superbowl through the TV speakers.
Comcast came and installed my HD cable box, and after they left I hooked up my audio system. After everything was connected, it worked fine. Now the next day I am getting a random buzz out of my speakers. It is most prominent in the left main speaker which is next to my audio rack. If I turn off the receiver I can still hear it through my powered sub.
I have tried...
-Disconnecting and reconnecting all speakers.
-Moving the main speakers to channel B instead of A.
-Disconnecting the sub.
-Moving the left front speaker away from my audio rack.
-Playing audio through the optical from the cable box and dvd player.
-Playing audio from the tuner.
It sounds like I pressed the test button...you know the one that sends a static buzz through the speakers so you can make sure they are all plugged in.
I really really appreciate any help I can get! Sorry about the long post!!
It is most likely a ground loop and are a royal pain to hunt down. A very short term fix is to get cheater plugs (the 3 prong to 2 prong AC adapters) to lift the ground on any gear that has a 3 prong plug. However, do not use this as a long term fix as there is a very remote chance of getting electrocuted if there is an quipment failure. As far as hunting down ground loops, there are a lot of threads on the subject and searching the forum is your friend.
Try our Hum FAQ in the Audio Theory, Setup and Chat forum.
Good luck.
Premium Member
zmzmsix it may be because you live in Ann Arbor Michigan.
GO BUCKEYES
1 - 4 of 4 Posts
Status
