1 - 6 of 6 Posts
this may be so far impossible, but i was wondering if it is possible to plug one of those usb hdtv tuners into the usb drive on my hdtv to pick up over the air hd signals? im guessing no, but just a thought.
doesn't your HDTV have a digital tuner?
Some HDTVs don't come with a built in tuner... mostly older models, though. I'd think the USB tuner wouldn't work for it.... most require software and an install on a computer. You could try I guess...
I would think if it's so old it doesn't have a digital tuner then it probably doesn't have a USB port either. I could be way off, though.
I have a semi-new HDTV, and I don't think mine even has a USB port, lol.
Easy_rhino, it would probably be best to simply buy a HD receiver STB. Look on the Circuit City or Best Buy website, and you'll find some good deals.
1 - 6 of 6 Posts
