1 - 3 of 3 Posts
I have an USB IR receiver that with my previous HTPC would properly wake up the system when I use the "power on" button from the remote. Everything worked well. Now I have a new HTPC (AMD Llano) and the receiver/remote combo does not wake the PC up from sleep. Ideas on how to fix this?
Join the club. I have the +5v setting enabled on the USB port my IR receiver is plugged into, by my problem is that when I configure the IR receiver to allow the PC to wake, it goes to sleep, then wakes again straight away!
I've had to disable this now, so while I can put the HTPC to sleep using the remote, I can't wake it, and have to use the power button on the front.
Never got to the bottom of the problem.
1 - 3 of 3 Posts
