I just got comcast cable installed and I'm having a little problem getting SageTV to reliably change the channel through the USB-UIRT. Sometimes it works, but only about half the time. Most of the time it fails is because the USB-UIRT is sending the codes too slow for the Motorola 5100 box. The box will get 1 or 2 then reset and recieve the rest, but since it isn't a complete entry, it just resets.
Is there any way to make the USB-UIRT send the codes faster?
