I currently have a USB-UIRT connected to a Xantech system. My goal is to use a PC to blast all my commands. I'm not using the IR receiver, basically im just using it as a wired system.
Anyways, my problem is that the system doesn't work very well. Some things work, but most don't. My 'heavy' equipment doesn't work (receiver, cable box, tv, e.g.). What does work is my projector and drapes.
Everything works fine when using a Xantech receiver, so im fairly certain the problem lies somewhere between the Xantech-USB-UIRT connection. Currently, they are both connected via a 3.5m stereo cable. I have searched around quite a bit on the internet and think I know the problem. It seems that these two products operate on different voltage levels (12v for the Xantech, 5v for the USB-UIRT. I know nothing of electronics so I don't know if the voltage difference can cause that problem, but at this point it's my only guess.
In all my searching, I have come across a product that seems to work for most people:
http://www.smarthome.com/8175/IR-Lin...Systems/p.aspx
The problem is that this product is discontinued.
I don't even know what that does nor do I have the technical knowledge to make my own circuit board. Can anybody help point me to an alternative product to interface my Xantech with my USB-UIRT? Thanks.
