I have viewed the forum many times before, but this is my first post. I started a build on a budget HTPC a couple years ago, but never really finished. My original goal was really just to have a mAtx PC to run HD movies on. As I lost interest waiting for the industry to decide the new format, the computer just collected dust on my a/v rack. Now I have decided to use the pc to run media portal and to record HDTV. Here is a quick run down of the current components that the PC is running with.
GA-K8N51GMF-9-RH socket 939 nVidia 6100 chipset
Athlon 64 3000+
MSI NX8500GT HDMI Out
1gig Corsair XMS DDR 3200
40" Samsung 1080p LCD
Attic Antenna for OTA HD
I am getting rid of DirectTV and will be exclusively using my OTA antenna.
So here are my issues / questions:
1) If I go internal tuner it has to be PCI low profile due to my graphics card taking up my PCI-e slot. I do not need NTSC or QAM. It has to be Windows XP or MCE 2005 compatible. I cannot find a well reviewed low profile PCI card for XP. Is there one out there?
2) I originally went with the pci card direction because I was worried about cpu consumption with software encoding on my outdated system. However, since I am only worried about digital signals is that really an issue. What about recording ATSC, will that cripple my system on a card without h/w encoding? Since it is so difficult to find a good PCI low profile card, is USB the way to go for my digital only needs?
3) What am I really giving up if I go either way since I am only worried about ATSC signals? Which USB tuners have a good mix of quality, sensitivity, and stability while keeping with the low budget theme that I have.
There is lots of info out there, but I still couldn't lock down a tuner that really fit my needs. Any help or opinions are greatly appreciated.
Athlon 64 3000+
