using 2 subs ?
376 Views 1 Reply 2 Participants Last post by  4DHD
If one was to use 2 subs in their setup do both subs need to be the same?I presently have a def.tech. 200tl sub that i may or may not replace but if i wanted to use 2 subs would i be ok just adding any other additional sub or would it be better with another 200tl.thanks
Status
Not open for further replies.
1 - 2 of 2 Posts
Different subs can be used, but using two subs that are the same model is best. I have two identical subs, one in the R/F corner and the other in the L/R corner. I also have another sub, same make, but different model, that I have set as a LFE sub. The two main subs are always on, music or movies. The LFE sub is only on for movies, but sometimes not even then.
1 - 2 of 2 Posts
Status
