i think most people just put a widescreen resolution on the TV, and let the internal scaler handle it. otherwise, things would be distorted.
Originally Posted by cafara For those of you that had to make this choice between LCD or Plasma..which did you pick, and why? |
Also, does anyone know any 42" plasmas that do 1366x768, it seems like if I could find one like that it would probably be my best choice, right? |
Originally Posted by cafara I'm looking into getting either a Plasma or LCD TV 37" or larger. I have a HTPC I will be hooking up to it, as well as a HDTV cable box, and probably an xbox 360 in the future. From what I have seen I have found that plasmas tend to offer much better colors, contrast, etc. I have been very impressed with the pictures I have seen off 42" plasma. The only concern I have is that most of them seem to have 1024x768 resolution on the panel, and I'm not sure how that will affect my use with the HTPC. The LCDs all seem to have something like 1366x768, which is a widescreen resolution and I'm sure will work much better with the PC. I am EXTREMELY worried about putting 1024x768 to the plasma. |
Originally Posted by cafara So would I basically be better off with an LCD TV? Which is better for something like xbox 360? I know the PC will look better on LCD, but wasn't sure about the xbox.....and I figure regular TV will look much better on the plasma |
Originally Posted by cafara What resolution does your plasma run at? Is it a 4:3 resolution like 1024x768? How bad is the stretching with the rectangular pixels? Basically, as long as it is tolerable, I would gladly get a plasma over the LCD. Thanks |
Originally Posted by mkoesel Well, like I said, my plasma is 50" so its got square pixels (1366x768). What is your budget? If you are considering 42" HD plasmas, it must be over $2k, correct? If you can manage to stretch that up to around $3k, you could get a Panasonic 50" 8UK. |
Originally Posted by lipcrkr So, if you are planning on incorporating your PC with a plasma the 50" will be much better than the lower rez 42"? |
Originally Posted by mkoesel I'm not sure I would say "much better". But it will give you the ability to run at native resolution without any distortion. Depending on what you plan to do on the PC and how particular you are, that could be a big deal or it could be completely unimportant to you. Heck there are some people out there using 852x480 ED plasmas with their HTPCs and loving it. I would not be able to stomach that, but what matters most is how it looks to your own eyes. |
