Status
Not open for further replies.
1 - 4 of 4 Posts
If I hook up my OTA antenna to my HDTV box using a diplexer to have only one wire coming in and then another to split the signals at the box, Can I still use my winegard 4800 preamplifier in the setup?
You need to be sure that you get diplexers that allow you to pass power. I have a similar setup and am using diplexers that only pass power on the antenna port. It is blocked on the satellite port so no frying of LNBs.
--Louis
Yes, you can still use your Winegard power amp. But make sure to install your OTA power amp and power supply before the 5x4 multiswitch ant in "uhf/vhf" input. If you install it after the multiswitch this will over power your sat signals. And you won't be getting any sat reception.
4 Sat coax & ota power supply to input of 5x4 Eagle ASPEN MULTISWITCH. Output 1 coax going to a dc pass diplexor then 2 coax seperating the Ota signal & Sat signal.
This is what my setup is and works very well.
Have fun with the project.
I have a RS double bow tie antenna hooked up to my DTC-100 and I can get only 1 out of 5 stations that broadcast digital in my area. I bought the RS amp that I have seen recommended on this board but it didn't do anything. The signal from the one station I could get before went from around 80 down to 65 and all other four stations are still too week for my DTC to lock onto them.
-Marc
1 - 4 of 4 Posts
Status
