  • Take part in a short activity and share your valuable opinion on new design concepts for AVSForum! >>> Click Here
Using a speaker selector with 1 tube amp, 1 solid state amp, and 1 pair of speakers
2571 Views 9 Replies 4 Participants Last post by  Bob Smith
Hi,
I am interested in setting up my system to use 1 pair of speakers with 2 different amplifiers. The solid state amplifier will be used for TV and DVD, while the tube amp will be used for my CD player.
Now I found the Russound AB-2.2 speaker selector which would let me hook up the two amps to one pair of speakers.
It was brought to my attention that it could possibly be dangerous to hook up a vaccuum tube amp to a speaker selector. There is no tech support I can contact for my tube amp, it's a non-branded model.
Would anyone be willing to make an educated guess as to whether or not THIS AMPLIFIER (take out the dash in e-bay, it was getting censored) would work safely with the speaker selector?
Oh and I emailed Russound tech support, and they said that it depends on the tube amp.
Status
Not open for further replies.
1 - 10 of 10 Posts
Yes, it will work provided the amp could handle a (infinitely) high impedance load, and I've never seen one that couldn't.
On the contrary. I've seen vacuum tube amplifiers output transformers short when the output is unloaded. If the (unloaded) tube amplifier is driven to clipping, the voltage on the primary of the transformer can become many times higher than the insulation is rated for. This can arc over, and carbonize a path and result in a short.
As a minimum, I'd put something like a 32 Ohm resistor, rated at 1/4th the 8 Ohm power rating of the amplifier across the vacuum tube's output to make sure it always has a load.
Another thing to be wary of is that some transistor amplifiers require a floating output on both the positive and negative outputs. Most switchers have a common ground, and using such a switch on this kind of amplifier (a bridge amplifer) will cause a short circuit between channels.
Hate to make this harder than it seems, but I'd hate for you to blow up an amplifier because you were told it was OK.
Bob Smith
See less See more
Thanks for the reply!
I see that there could be potential problems.
How about if I only switch it while both amplifiers are turned off? So saying the switch is in "Amplifier A" state, only the amplifier hooked up to "Amplifier A" input will be turned on. If I want to switch to amplifier B, I would power down amplifier A, switch to "Amplifier B" state, and then turn on amplifier B. Wouldn't that mean the output is never unloaded while the amp is on?
Thanks Bob! In this type of situation I'm very glad to be corrected.
Actually, Bob, that raises a question. Is it the transition between output impedances that is the problem? I answered as I did because I don't recall seeing a tube amp with warning stickers about firing it up without a load.
I know when I bias the tubes on my integrated the instructions say to disconnect everything and place it on a table, etc. I have biased it this way numerous times with no issues.
If you're also sure you never power it up and turn the volume control up on the tube amp while it is not connected to a load, that will be OK. If you turn up the volume because you THINK it's connected, and the amplifier goes into clipping, then you'll have problems. It's not guaranteed it will do damage, but the potential is there. If the transformers have enough insulation to take the overload, they may be OK. If, however, they don't, you will have an expensive transformer to replace, and the output transformer is about the most expensive thing in the amplifier.
The rule I always use is never leave a tube amplifier with an open output, and never place a short across a solid state amplifier. Tubes are very forgiving of a short on the output transformer, but not an open. Transistors (depending on the short circuit protection circuitry) are not.
I wouldn't take a chance.
Biasing the tubes with no output is probably OK, because usually when the bias position is selected, the input is disconnected ( I believe that's the way it works on my Marantz Model 9s).
With push-pull outputs, there isn't quite as much of a chance of doing damage either (though I've seen them burn out as well). This is because the conducting tube in the output stage will load the transformer when the other tube is cut-off.
A single-ended amplifier is much more vulnerable because when the output stage cuts off during clipping, the transformer (which is just a big inductor when not loaded) generates a back EMF to keep the current across it constant. UsingE= L(di/dt) , when the current instantly goes to zero (during clipping), the voltage can reach infinity. Usually this isn't the case, but it is possible for the voltage to go to several times the B+ of the amplifier. Most transformers are only rated to go to twice the amplitude.
All in all, as expensive as output transformers are, I wouldn't take a chance.
As I said, using a 32 Ohm resistor or so that never gets disconnected from the amplifier is probably the safest bet.
See less See more
Originally Posted by Bob Smith
...using a 32 Ohm resistor or so that never gets disconnected from the amplifier is probably the safest bet.
Thanks for the explanation Bob Smith, although I didn't understand it all :p
Now, if I were to use a 32 Ohm resistor, how would I go about doing that? Would it involve actually opening up the amp and soldering something inside, or is there an easier way which isn't so technical, that I could just hook up to the back of the amp?
Thanks again-
Thanks again-
Just put it across the speaker terminals in parallel with the speaker leads. It's going to rob some of your amplifier power from the speaker, in fact, for an 8 Ohm load, you're going to lose about 25% of your power (about 1.25 dB, just barely noticable) but you will be safe.
You should also make sure the switch is 'break before make' and that both positions can't be selected at the same time (many speaker switches allow both speakers to be connected at once) so that the solid state amp won't drive the transformer of the tube amp.
Even more important, if the tube amplifier is on while connected to the unpowered solid state amplifier, it could do some serious damage to the output stage of the solid state amplifier. With the solid state amplifier off, there is nothing to prevent the output transistors from being 'back biased' from emitter to base. If this is over 5 volts or so, the output transistors may be destroyed.
Sorry about all this paranoia, but I get queezy when the outputs of power amplifiers are switched while they are in operation, lots of things can go wrong when you're shoving so much voltage and current around and it gets 'misplaced'.
Bob
See less See more
1 - 10 of 10 Posts
Status
