1 - 8 of 8 Posts
I have a 7.1 system and wanted to ask what others set the fronts, sides and rears at with an SPL,,
is it advisable to have them all at the same level or fronts higher, sides a tad lower and rears a little lower than the sides,,??
curious what others have determined to be the best settings,,
thanks
Derry
fronts Altec Voice of Theater
center Def Tec 2500
sides Def Tec 7002
back Def Tec BXP
sub SVS pb13 ultra
receiver is Marantz SR9600
Banned
thanks
Derry
center Def Tec 2500
sides Def Tec 7002
back Def Tec BXP
sub SVS pb13 ultra
A good starting point would be zero for your viewng seat, than fine turn to your tasts.
Discussion Starter · #5 ·
I used the Marantz auto system to set all the spekers with the microphone at the main seating station,, when I chek them with the spl meter thay are different by a few DBs,,
thanks
Derry
So, which one do you trust?
Discussion Starter · #7 ·
the SPL meter,,
ran it again last night to balance them all out and could hear the difference,, in Dark Night there were scenes that I felt as though I was sitting in the center of the action which I never had when using the Marantz for auto set up,,
when two identical speakers register three and four DB difference with the meter in the same location in front of each speaker it is hard to see how the meter would be wrong,,
I know I like the sound envelop better using the meter,,
Derry
Originally Posted by Derry /forum/post/18270827
the SPL meter,,
Really? I generally do not unless the meter is calibrated and the test signals are defined/controlled.
That is dependent on the radiation characteristics of the speakers and the spatial sensitivity of the meter. Besides, one should be measuring each of the speakers from the same position, the listening position, rather than from "the same location in front of each speaker." In addition, the aiming of the meter/mic is critical.
That's a different kettle of fish.
1 - 8 of 8 Posts
