Thanks Dom, I'm just re importing my init file to see if any changes.. Then I'll do the same measurements and send the file again. Thank youThere is some strange clipping in the red channel. You have to figure out what is causing this. How many modes did you run Autocal in? Switch to an uncalibrated mode and see if it has the same issue.
Also, your colour space setting in HCFR should be Rec709, not sRGB, although that's not the cause of the problem.
Sent from my VOG-L09 using Tapatalk
